AT No 4th or 1st Gear
Old Mar 12, 2008 | 12:35 PM
jeff_falk2007's Avatar
jeff_falk2007
Default AT No 4th or 1st Gear
1994 Acura Integra B18B with CVT Auto Trans.....Will not start out in Drive4 or Drive3 I have to Shift to 2nd to start and then shift to 3rd....fluid level is at maximum no vacuum lines or wiring unhooked. I had my front right CV axle changed out and drove it home, shut it off and went to go to work and then the no 1st or 4th gear. When i go to downshift to 1st it doesnt have as much power output as Second gear. I dont have very much money to work with as of right now, and I use this car for work. What should I do? Should I have it rebuilt? Or is there something I can do myself?? Thank You For Your Help...If it can be helped, I need feedback ASAP.
