Gauge Cluster
Old Feb 12, 2008 | 06:07 PM
Cyrex17's Avatar
Cyrex17
Default Gauge Cluster
I have a 92-95 civic coupe. I have an B18C swap. Before the swap my speedometer was working intermittently. Just recently my tachometer died and stopped working completely. I thought my gauge cluster was the problem so I bought a JDM gauge cluster. I plugged it in and started the car and still no tachometer reading. I didn't run the car with the new cluster so I don't know if the speedo is completely working or not. I also noticed that the JDM cluster does not have a socket to plug a yellow and green plug. What are those wires for? Is it important for me to plug those in? Do I need to re-wire those somewhere?
Old Feb 15, 2008 | 08:37 AM
Mister Jew's Avatar
Mister Jew
The jdm cluster is plug an play you dont have to plug in those 2 misc plugs. if i were you i would check your distributor i believe thats where the rpm pickup is at. Is everything else in the cluster working properly? temp, gas and, speedo?
Old Feb 16, 2008 | 06:58 PM
Cyrex17's Avatar
Cyrex17
The speedo is not working 100%. It stops working intermittently. I replaced the speed sensor. I still have the same problem. Temp and gas are working fine. I have been reading other threads and a lot of them say it might be the distributor. Is there anything in particular I should be checking?
Old Feb 19, 2008 | 09:20 PM
cadwiese's Avatar
cadwiese
i also have a problem like this in my eg with a b18b swap
Old Feb 26, 2008 | 09:58 AM
primetime's Avatar
primetime
check to see if the speed sensor wire are loose.
Old Feb 26, 2008 | 02:18 PM
Civic2Scooby's Avatar
Civic2Scooby
its a distro problem for the tach, its the blue wire coming out. check to see it isn't pinched/cut/etc. You can also do a resistance test across the wire from the dizzy to the cluster with a DVOM.
