HELP!!!!!B16C problem
Old Jan 30, 2008 | 06:39 PM
blk.dice's Avatar
blk.dice
Default HELP!!!!!B16a problem
i got a problem with my b16a engine i swap it and put it in a honda hatchback(1992) when i tried to started it will ignite but will not start i checked the spark plugs wire and it won't make a spark and the fuel pump doesn't even start when i turn the key(acc) also the only light in the dashboard will lit is the one when you got the doors open for the rest theres no other i change the spoon ECU to an original ECU but nothin happen can somebody help me because i really want start the car to finish it
Old Jan 31, 2008 | 05:33 AM
SHUA619CIVICSI's Avatar
SHUA619CIVICSI
1991 CIVIC SI
Originally Posted by blk.dice
i got a problem with my b16c engine i swap it and put it in a honda hatchback(1992) when i tried to started it will ignite but will not start i checked the spark plugs wire and it won't make a spark and the fuel pump doesn't even start when i turn the key(acc) also the only light in the dashboard will lit is the one when you got the doors open for the rest theres no other i change the spoon ECU to an original ECU but nothin happen can somebody help me because i really want start the car to finish it
theres no b16c theres a b18c if that is what ur talking about
Old Jan 31, 2008 | 12:06 PM
blk.dice's Avatar
blk.dice
oww yeah sry its a b16a can you help me
Old Jan 31, 2008 | 12:13 PM
B16a2VTIguy's Avatar
B16a2VTIguy
Built B16a
when you swapped the engine into it, did u use the b16a wiring loom or the original loom? Was the b16a engine from a newer civic with obd2 wiring?
Are you using the original ecu or the b16a ecu?
Old Jan 31, 2008 | 12:23 PM
blk.dice's Avatar
blk.dice
i used a 2 door civic wiring harndass and i used the original motor wire harndass and i dont know if the engine was form a newer civic because i bought it on ebay i tried with the original and a spoon ECU but does the seem thing nothing happen with the fuel pump and wont make a spark at the spark plug wires
Old Jan 31, 2008 | 12:27 PM
blk.dice's Avatar
blk.dice
but the guy who sold it to me sad that it is a running engine and i thing it was in a integra 1994
