***help Car Wont Start, Don’t Know Whats Wrong, Need Help***
Old Jan 3, 2008 | 05:30 PM
Inmotion's Avatar
Inmotion
Default ***help Car Wont Start, Don’t Know Whats Wrong, Need Help***
***HELP CAR WONT START, DON’T KNOW WHATS WRONG, NEED HELP***
The timing belt broke on my 95 Integra GSR. (I know maybe the valves might be bent, etc. That’s not what I’m worried about at the current moment!!). Me and a friend changed out the timing belt and re-aligned the pulley and cam gears with almost exact precision (wont know for sure until I get the car started). We put everything back together and when we tried to start the car nothing happened, the starter did not even click. During the timing belt-changing process my friend only disconnected the positive on the battery and left the negative attached (big fuck up). This is what is happening: when you turn the key (before ACC) there is no check engine light, no oil light, no battery light, and only the abs turns on, basically all the usual lights that are supposed to appear on the dash do not appear, Also, the fuel pump doesn’t even turn on. When you turn the key (to ACC) and step on the clutch nothing happens, the starter doesn’t even click, I mean NOTHING, and the oil and check engine light appear very lightly. A lot of people keep saying that its something with the timing belt, but I don’t believe that because if that was the case then the starter should at least click and all the dash lights should turn on, just like before we changed the timing belt. We already checked all the fuses (under the hood, and under the dash), we checked for lose connections (in the engine bay and under the dash), checked the ECU (still good), checked all the grounds (in the engine bay), we also changed the main Relay under the dashboard and put in a new one, checked the battery. We even tried to jump start the car, and also push start the car and nothing happened. Me and all my friends that have helped me look for the problem are totally confused and stumped. Don’t understand what the hell happened. This problem has left me car less, I need input ASAP. If anyone might know what is happening or what is wrong PLEASE LET ME KNOW ASAP. I need to get my car up and running again. THANKS FOR YOUR HELP.
PROBLEMS:
-No check engine light, no oil light, no battery light, fuel pump doesn’t turn on.
-Starter doesn’t even click when key is turned to ACC
-Nothing happens, its like the car is dead
CHECKED ALREADY:
-All fuses in the engine bay and under the dashboard
-Checked for all lose connections
-Checked all grounds
-Changed the main relay under the dashboard
-Checked the ECU
-Checked the Battery
-Tried to jump start the car, and push start the car
