Build Question
Old Nov 20, 2007 | 12:32 PM
B16a2VTIguy's Avatar
B16a2VTIguy
Built B16a
Default Build Question
I have the following build,
B16a1
B16b pistons (ek9)
skunk 2 stage 2 cams
Head skimmed by 30 thou
Is it likely i will have any issues with piston to valve clearance?
I know ive got to pre-build it to test this, but how can i check
clearance for when vtec engages?
Old Nov 22, 2007 | 10:57 AM
B16a2VTIguy
Built B16a
No one know then??
Thought there were a few folk on here running high compression n/a builds!
Old Dec 4, 2007 | 10:12 PM
effilcdar's Avatar
effilcdar
Default vtec
If you want to check the clearance for when vtec engages plumb an air line at ~20 psi to the access port on the oil line that engages vtec. Then either jumper the solenoid or plug the outlet(the port into the head just inside and down from the vtec solenoid) and it should catch onto the high lobes when you rotate the engine over. Just remember that this is a dynamic system. You'd be surprised how much stretch there is in the connecting rods at high rpm
Old Dec 9, 2007 | 11:35 AM
B16a2VTIguy
Built B16a
Thanks, but what do you mean by this? sorry if im being dumb
Old Jan 7, 2008 | 12:17 PM
B16a2VTIguy
Built B16a
Built this engine and with the standard timing there are no clearance issues.
Just thought id post it up incase any one ever does a similar build.
