Gsr Rebuild Swap No Start
Old Nov 18, 2007 | 09:24 AM
94d16turbo's Avatar
94d16turbo
Default Gsr Rebuild Swap No Start
It been # days since I been trying to fix this problem. rebuild a gsr motor for turbo setup. New piston rod, valve spring, and everything. the motor drop in the car. all ground harness at puck in. go to start. it turn over with spark fuse. and timing on the dot. try it 4 time to retime it. No i got to a problem than it has all it needs to start why won't it start. sound like it wanna turn on, but it won;t kick on. anyone got any clue wat be the problem to solving this.
Old Nov 18, 2007 | 12:33 PM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
If the coil and igniter are known to be good and the timing is on spec, then the next question is fuel pressure.
Confirm that the pump is functioning, then check fuel pressure at the fuel rail. If you have proper pressure at the rail, then I'd suspect the injector wiring.
And since this is a swap into a Civic, this thread needs to be in Engine Tech / Swaps.
Old Nov 20, 2007 | 11:54 AM
94d16turbo's Avatar
94d16turbo
thanks for the help. i found out. misfire order and one ground was miss. i;m so fucken stupid. lolz. hahaha.
