GSR vs. SI ecu
Old Oct 14, 2002 | 05:35 PM
speed614's Avatar
speed614
Civic GSR Driver
Default GSR vs. SI ecu
Whats the differnce between the GSR and SI ecu? If i have a GSR swap would it worse if i ran a SI ecu then an actually GSR one?
Old Oct 14, 2002 | 05:59 PM
Bumnah's Avatar
Bumnah
So OG it hurts.
gsr ecu kicks in the secondaries, while the si ecu wont.
vtec crossover would be different also. i believe the b16 switches over at 5400, while the b18c's do it at 4500.
get the gsr. you want the secondaries to kick in.
Project EVA - The Track Package
Project EVA
Old Oct 14, 2002 | 06:01 PM
speed614's Avatar
speed614
Civic GSR Driver
Yea thats what i was thinking, i have a 2001 GSR swap and that immobilizer **** is causing problems. Can i just use a 96-99 Ecu that doesnt have the immobilizer on it?
Old Oct 18, 2002 | 07:04 AM
sleepin's Avatar
sleepin
You sure about this?
I thought the secondaries were vacuum controlled, not ECU controlled.
at least on my lude swap there were no wires running to my secondaries just the vacuum lines.
Old Oct 18, 2002 | 08:05 AM
Bumnah's Avatar
Bumnah
So OG it hurts.
yes they are wired up to the ecu
Secondary Intake Solenoid Pink/Blue A17
What year is your car? I take it your swap is 2001 since you said that.
Project EVA
Old Oct 18, 2002 | 08:16 AM
speed614's Avatar
speed614
Civic GSR Driver
My car is a 2000 civic EX
Old Oct 18, 2002 | 08:25 AM
sleepin's Avatar
sleepin
Now that I think about you are right, sorry.
No, I had a 95 H22, but I also was not using my secondaries. (had them removed).
