with 10psi of boost can
Old Oct 14, 2002 | 08:59 AM
acurars's Avatar
acurars
Default with 10psi of boost can
what would i have to do to be able to run 10 psi of boost in my 94 teg with 117000+ miles?and can i run nos with it?
Old Oct 14, 2002 | 02:17 PM
qtiger's Avatar
qtiger
If your engine is in good shape, you could run 10 psi of boost with a full sized intercooler and good, proper tuning.
I wouldn't do it daily though.
Nitrous over a 20 shot would make things dangerous without additional modification (rods, pistons)
Old Feb 16, 2003 | 03:06 PM
TeHJuSTiN's Avatar
TeHJuSTiN
NAM #0001
As qtiger says... "If your engine is in good shape"
If you want to run 10psi on basically stock everything, make sure you have enough fuel modifications to run that. Many people seem to forget that. On a stock engine I honestly wouldn't run any nitrous with boost. But if you were to go purely n2o then I'd say you could easily run 50shot stock, 75 shot with new injectors, fuel pump, and fpr.
Tuning is the essence of all good.
Old Feb 16, 2003 | 03:45 PM
Speed Phreak's Avatar
Speed Phreak
Turbomafia
Default Re: with 10psi of boost can
Got NAWWWSSSSS!?
I wouldn't run NITROUS OXIDE or n2o without built internals on a boosted car. N2O and boost make good bed fellows but only when your tuning is good. A 20~35 shot is about all thats needed for a good power boost on turbo cars. It's just enough to drop the intake temps way down, the boost does the rest. But like I said, if your tuning is good it'll scream, if not......it'll go boom.
~Steven
