Cams B16A vs GSR B18 not Type R
Old Jun 14, 2007 | 05:29 PM
2slowCrx's Avatar
2slowCrx
Default Cams B16A vs GSR B18 not Type R
Which is better(Cams B16A vs GSR B18 not Type R)?
My buddy just bought an extra GSR motor w/ Type R Cams which he plans on putting in his old motor. His old motor has stock GSR cams which he's willing to just give/trade me because he's not going to use them. He says it would give me 4hp and I wouldn't need double valve springs. Is this true and would there be any negative changes to my power band now?
Old Jun 14, 2007 | 05:31 PM
Snoopy's Avatar
Snoopy
been there done that
if he's going to give them to you just put them in. dont expect anything huge.
Old Jun 14, 2007 | 05:35 PM
2slowCrx's Avatar
2slowCrx
Would I get 4bhp?
Old Jun 14, 2007 | 05:37 PM
Snoopy's Avatar
Snoopy
if you did you wouldnt notice
Old Jun 14, 2007 | 05:48 PM
2slowCrx's Avatar
2slowCrx
If I was going to Type R. What would total swap cost (Double V. Springs, Cams)? Hp on that would be 7-9bhp correct?
Old Jun 14, 2007 | 05:49 PM
2slowCrx's Avatar
2slowCrx
Why do you say I wouldn't notice hp is hp correct?
Old Jun 14, 2007 | 10:54 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Depends on labor costs, where you purchase the cams and valvesprings, and who did the tuning. You can pick up a used set of ITR cams for $300 and ITR valvesprings for $100.
The hp gain would be dependent on the tuning used. With a set of adjustable cam gears and a basic piggyback unit to adjust the vtec engagement point and even out the fuel curve, you would definitely notice a decent gain.
4 hp is not going to be noticeable on the butt dyno.
Old Jul 6, 2007 | 11:14 AM
qtiger's Avatar
qtiger
GSR cams are very slightly hotter than b16 cams. If I remember right they have 3 degrees longer duration or somesuch. If you're really bored you can install them, but I'd be surprised if you got more than 2 hp out of it.
If you're going to spend money to upgrade your cams, I'd skip ITR and go to Skunk2 stage 1 cams. They've always shown really nice gains on b16s and you can use your stock springs so long as you don't rev over stock redline.
