Need help on a chipped ecu ASAP...
Old Oct 10, 2002 | 06:14 PM
sir_crx's Avatar
sir_crx
Default Need help on a chipped ecu ASAP...
I hate paying people to do what looks like something I can do, I have all the correct tools, and am capable, but have never done this...now I bought a chip for my P28, did the w/ instructions, and the ecu will not rev past 4000 rpm Please someone help me, the only problem I can see is that I was shipped (2) 104 capacitors and the instructions call for (2) 103. Is this THAT much of a difference? Please, anyone that has chipped an ECU tell me what I'm doing wrong. I feel stupid. I can normally do anything I want to do and feel that this is an easy fix but I need some guidance from someone who has done it allready, thanks.
Old Oct 10, 2002 | 11:56 PM
KillerB17's Avatar
KillerB17
Call hondata
Old Oct 11, 2002 | 04:06 PM
sir_crx's Avatar
sir_crx
I will trying calling monday but what about other suggestions???
Old Oct 11, 2002 | 04:56 PM
dubcac's Avatar
dubcac
I
Sounds like a bad chip, maybe you shocked it.
Old Oct 12, 2002 | 05:42 PM
sir_crx's Avatar
sir_crx
I handled it very carefully...rubber gloves even?!?!
Old Oct 13, 2002 | 07:49 AM
one11racing's Avatar
one11racing
In my own world
if you handled it with rubber gloves then most likely the static in the glove hurt it. the other factors is the heat range of the gun you used to solder it in. or wattage if you want.but either way the chip is dead. just cut the J1 crossover and the ecu should go back to stock.
Old Oct 14, 2002 | 06:12 PM
sir_crx's Avatar
sir_crx
I installed sockets so the chips could be changed, I didn't heat the chips, could it be the capacitors? 104 compared to teh required 103?
If I did shock it, how could I go about not doing that next time? Any special precautions?
Old Oct 16, 2002 | 05:17 PM
sir_crx's Avatar
sir_crx
I fixed the prob, thanks to those who helped.
Old Oct 16, 2002 | 06:13 PM
dubcac's Avatar
dubcac
I
Was it the capacitor?
Old Oct 17, 2002 | 10:39 AM
sir_crx's Avatar
sir_crx
Both of them actually. I'm going to start chipping ecu's in partnership w/ a friends import shop.
