attention so cal swapers
Old May 24, 2007 | 08:44 PM
trevek10's Avatar
trevek10
Default attention so cal swapers
hey guys like you i live in so cal and are a victim of stupid hybrid haters ... but i have been still wanting to do a close to legal swap into my 99 ek.. its way easier to find a jdm b series than a "usdm" i plan on doing a jdm b16a2 into it and besides the same year engine... i have found out that i need all the emis.. sensors of a us version along with an ecu/ can i use a aftermarket ecu or no? i want to get it bared and all that... wht else do i have to worry about? anyone know..... :shrug:
Old May 25, 2007 | 02:08 PM
trevek10's Avatar
trevek10
hmmm.. anyone know anything about the whole ecu thing???
Old May 28, 2007 | 11:52 AM
sekongen's Avatar
sekongen
Call this # 1800-622-7733. It's the hot line to schedule a ref appointment. You can call this number and request your local B.A.R ref. I am assuming you are in California. I myself am in San Diego and my local refs name is Michael Muller of Southwestern college in Chula Vista. When you call, the operator will ask you a basic rundown of your setup, then will send the info to the ref. The ref will call you within a day or so and go through step by step everything he or she will look for on test day. Some refs will let certain things slide and some wont. But whoever it is they will lead you in the right direction. It is a very simple process and it only costs about $40. Hope this helps,
Eric
Old May 29, 2007 | 08:33 PM
trevek10's Avatar
trevek10
k before i call and get everything for the certain app/// perhaps someone can let me know if i can run aftermarket ecu.. and which ?
Old May 29, 2007 | 08:35 PM
trevek10's Avatar
trevek10
one more thing is there a problem with jus plugin in a usdm ecu .. ??there shoudn't be right
Old Jun 1, 2007 | 02:05 PM
trevek10's Avatar
trevek10
anyone/.
Old Jun 2, 2007 | 10:23 AM
sekongen's Avatar
sekongen
I pretty sure you just have to run vtec an knock sensor lines and the b16 ecu should plug right in. Provided its the same OBD. if not then you have to get a jumper harness. just call the ref anyways. you dont have to make an appointment right away. you can just talk to them over the phone and they will tell you exactly what you have to do (what ecu, harness, etc.) and there is no pressure to set up a face to face appointment right then and there.
Old Jun 19, 2007 | 01:53 PM
trevek10's Avatar
trevek10
gothca thanks
