b18b head on a b20 block?
Old May 19, 2007 | 06:41 PM
FearTheTruth34's Avatar
FearTheTruth34
Default b18b head on a b20 block?
first things first i got a b18a and a b18b head, i heard the b18b head is less restrictive than the a head, i am going to have a good port, polish, and valve job done it one of the heads, and then put that back onto my block, also doing cams. would it really matter what head i port and polish out?
also am doing a new bottom end, want to know what it would take to put in a b20 block with the b18 head on it? any special head gasket? or would a b20 head gasket work?
Old May 19, 2007 | 08:31 PM
18crx's Avatar
18crx
stock booster
same thing and theheads flow the same as a 1.8 why unless its already done. but oh well. good for you to do a no vtec b20.
Old May 20, 2007 | 05:32 AM
FearTheTruth34
so a b20 head gasket would work on this? and im doing a nonvtec setup just because vtec is probably the most overated variable valve timing out there...cant stand when a ricer says, 'yeah i got vtec!' UGHHH but yeah i got a b18b motor in the car now, and a 2nd b18a head, thats gonna get a good port and polish, valve job, and pretty aggressive cams, and im thinking about doing a high compression b20 bottom end...
Old May 20, 2007 | 11:30 AM
18crx's Avatar
18crx
stock booster
well youll get a little more torque outa the b20 casue of the displacemnt..
yes it will work.
im doing turbo cams in my ls. with just the cams i can rev 1000 higher and make power there also make 15 horse on the dyno and 7 more torque in na form. delta cams yeah.
Old May 20, 2007 | 03:56 PM
KaoticBRD's Avatar
KaoticBRD
The B18b head will work just fine on the B20 block most B20s already have the B18b head p75. Just use a B20 head gasket and thats all you need everything is the same.
Old May 20, 2007 | 04:03 PM
Snoopy's Avatar
Snoopy
been there done that
wtf?
Old May 20, 2007 | 05:04 PM
FearTheTruth34
haha snoopy sorry man, just not a big fan of it...its good, but it doesnt compare to the celica gts lift
Old May 20, 2007 | 06:41 PM
Snoopy's Avatar
Snoopy
:eh:
you sound just like every other ricer i've come into contact with
Old May 20, 2007 | 07:07 PM
FearTheTruth34
im allowed to have my opinions am i not? i just would rather build a nonvtec setup...sorry...didnt mean to piss you off
