Gsr swap loose ends
Old May 17, 2007 | 11:25 AM
sekongen's Avatar
sekongen
Default Gsr swap loose ends
Hello all, I have a 93 integra and I am in the process of getting a JDM obd1 B18c (sir-g) reffed and bar'ed. I gave the ref a run down on parts I have accumulated
in order to make the swap legal and he said all I need now is a USDM throttle
body and USDM P72 ecu. Now I know there is no way around the ecu
I have to use but are there any other options as far as oem TB's I can use? I guess the main thing is having a TB with the MAP sensor mounted on it. Does anyone have any relative experience pertaining to this matter? Is there a way to use my stock LS TB? Thanks in advance,
Eric
Old May 19, 2007 | 06:29 AM
primetime's Avatar
primetime
Eric
You can't use an LS throttle body! you are going to have to get an oem gsr TB or an Aftermarket TB like skunk2.
Old May 19, 2007 | 04:11 PM
sekongen's Avatar
sekongen
Thats what I had figured. Thanks for the reply. Oh well, time to spend more money...:a:
