turbo exhaust
Old May 14, 2007 | 05:46 PM
foshomofo's Avatar
foshomofo
Default turbo exhaust
Im not sure as to what size ehaust i should run for my turbo setup. I have a fullrace topmount, and a 4" DP. i will be boosting 28psi max, and i dont know what exhaust to get, if any. would open DP be ok? i know it will be loud as balls, so im kinda iffy about it, and i dont know if turbo cars need back pressure like all motor cars do..this is my first turbo build, and im attempting to go pretty big on this build. i will be driving this car on the occasional sunny saturday as well, on probably 14psi. help.
Old May 14, 2007 | 06:03 PM
Snoopy's Avatar
Snoopy
been there done that
open DP all the way if this thing isnt driven daily
Old May 14, 2007 | 06:13 PM
foshomofo's Avatar
foshomofo
well. thats not the plan...but...ive ridden in some friends boosted cars..and..um..i think it will be tough to keep myself from driving it 24/7...is open DP that loud?
Old May 14, 2007 | 07:43 PM
Snoopy's Avatar
Snoopy
the turbo itself will help quiet things down. but it's still going to be loud. if you want to run an exhaust might as well get something 4'' all the way back.
Old May 18, 2007 | 11:51 AM
18crx's Avatar
18crx
stock booster
i bet it will be loud if your going to run some big turdbo then it will be louder than a small one.. but driving open dp at 55 0r 60 kinda gets old cause its a droaning sound.
Old May 19, 2007 | 06:43 AM
ls_on_boost's Avatar
ls_on_boost
ls_on_boost
if you run open downpipe doesn't that make you slower because theres no back pressure
Old May 19, 2007 | 09:03 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
Back pressure is a very bad thing on turbocharged setups. The faster exhaust gases are evacuated from the manifold and wastegate, the faster the turbo will spool.
Old May 20, 2007 | 11:36 AM
18crx's Avatar
18crx
stock booster
agreed turbo would be the best with no exhaust right after the turbo
Old May 23, 2007 | 08:17 AM
QuikSilver's Avatar
QuikSilver
Are we Teg yet?
Well damn! I'll just run a flex pipe from my turbo right out my hood. Haha, maybe not.
Old May 28, 2007 | 05:46 PM
laziebun's Avatar
laziebun
Thermal 3"
