using abs axles on non-abs car??
Old Apr 18, 2007 | 05:17 PM
Snoopy's Avatar
Snoopy
been there done that
Default using abs axles on non-abs car??
95 civic ex with no abs with b18c1 swap. has a torn cv boot so i might as well replace the axles. would i be able to use integra abs axles no problems?
Old Apr 18, 2007 | 05:31 PM
Snoopy's Avatar
Snoopy
ok it looks like i can take the abs rings off abs axles and they'll work fine. anyone confirm?
Old Apr 18, 2007 | 07:07 PM
FLAT_LINER's Avatar
FLAT_LINER
Ridin Dirty
yep...they will work just fine
Old Apr 18, 2007 | 07:22 PM
Snoopy's Avatar
Snoopy
sweet. need to jump on this soon. it's gonna suck.
Old Apr 18, 2007 | 09:47 PM
dubcac's Avatar
dubcac
I
Yeah, you just have to bang off the ABS ring, which can be a pain. I did this on my integra...had a non-abs axle from my roommate's old civic..so I took the ABS ring off my bad axle, and put it on the civic axle.
Old Apr 19, 2007 | 12:40 PM
Snoopy's Avatar
Snoopy
how difficult is it? never had to deal with something like this before.
Old Apr 19, 2007 | 01:41 PM
dubcac's Avatar
dubcac
I
It's easy, it just can be a pain/time consuming trying to bang it off with a flathead and a hammer.
Old Apr 19, 2007 | 03:28 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
You don't have to take off the ABS ring. There is no sensor, so it won't even matter if the ring is there or not.
Old Apr 19, 2007 | 03:31 PM
Snoopy's Avatar
Snoopy
ah ok. thought it would cause fitment issues. but thanks.
Old Apr 19, 2007 | 03:50 PM
Provocateur
On permanent hiatus
It shouldn't. The only difference between the two systems just looking at the hub is an ABS system has a sensor and a non-ABS doesn't.
If you want to pry off the ring, go for it. If you don't, you won't experience any problems.
