Hone and piston size
Old Apr 16, 2007 | 05:18 PM
FearTheTruth34's Avatar
FearTheTruth34
Default Hone and piston size
i want to just rehone my block so i can break in my new rings, will i need oversized pistons or will stock bore do?
Old Apr 16, 2007 | 05:24 PM
Snoopy's Avatar
Snoopy
been there done that
stock bore is fine. a hone doesnt take material away from the cylinders like a bore.
Old Apr 17, 2007 | 01:36 PM
FearTheTruth34
would it also be possible to use a b18b head on a b20 block? and if not, whats the rev limit stock on a b20?
Old Apr 17, 2007 | 01:39 PM
Snoopy's Avatar
Snoopy
b18b and b20 heads are essentially the same
Old Apr 18, 2007 | 08:37 AM
dubcac's Avatar
dubcac
I
As long as you don't hone away too much material, you'll be fine using the stock bore pistons.
Old Apr 19, 2007 | 09:47 PM
2001TEGGSR's Avatar
2001TEGGSR
I wouldn't rev a stock B20 higher than the OEM rev limit without some modification, namely ARP rod bolts or aftermarket rods. If your having the block honed by a machine shop, OEM rings should be fine.
Be sure your ring gap is calculated correctly!
