What will happen if we used the wrong spark plug?
Old Apr 9, 2007 | 11:34 AM
ivan323's Avatar
ivan323
Default What will happen if we used the wrong spark plug?
Hi guys, i brought the wrong NGK Iridium spark plug model for my Honda civic EK SiR B-series model.
Will i damage the engine or cause any problems to it?
After i had changed, i kinda smell some sort of buring smell inside my car.
I'm quite worried is it the cause of wrong model of spark plug i brought?
I brought ZFR6FIX-11 instead of BKR6E-N-11..
Old Apr 9, 2007 | 12:38 PM
Snoopy's Avatar
Snoopy
been there done that
dont worry about it. just make sure the gap is correct.
Old Apr 9, 2007 | 09:22 PM
qtiger's Avatar
qtiger
If you bought completely the wrong type/size/etc of spark plug you could completely destroy the engine, you'd shatter the plug with the piston and the bits would go everyplace.
If you just have the wrong line of plug, it's not a big deal.
Old Apr 10, 2007 | 08:10 AM
ivan323's Avatar
ivan323
I dun understand wad u mean by the gap is correct.
Which gap u mean?
Sorry, i'm very new into engine stuffs..
Old Apr 10, 2007 | 12:18 PM
silvic00's Avatar
silvic00
that should help you understand
Old Apr 10, 2007 | 12:40 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
The proper plug gap should be .044" on that motor.
Old Apr 10, 2007 | 12:47 PM
Snoopy's Avatar
Snoopy
actually dont even worry about the gap. those are already pre-gapped to .044"
you can tell by the 11 in the part number. that means it's gapped to 1.1mm = .044"
i just put the bkr6e-11 in my b18c1 with no problems
Old Apr 11, 2007 | 07:05 AM
ivan323's Avatar
ivan323
Ok. I kinda understood wad u mentioned.
But i'm really worried the burnt smell after when i removed the spark cable.
I think i better dun save tat bit of $ rather having major problems in future..
