Bubbles inside raditor
Old Mar 15, 2007 | 08:41 AM
ivan323's Avatar
ivan323
Default Bubbles inside raditor
Hi guys, i have a problem again..
When my engine idling, i see bubbles popping up inside my radiator tank after i open my radiator cap.
I even encounter loss of 1/4 coolant inside my spare tank.
Is this the sign of gasket blown?
I had changed my head gasket, radiator fan, themostat, radiator cap, flush my radiator a few times n even timing belt n water pump just few months back.
Its even less than 10,000km of driving.
Is there any other causes of this?
I'm driving a Civic ek4 SiR.
Old Mar 18, 2007 | 04:50 PM
honda_newbie2's Avatar
honda_newbie2
did you get all the air out of the system when you flushed it? the engine has a blead valve
Old Mar 19, 2007 | 07:22 AM
ivan323's Avatar
ivan323
I didn't flush my coolant at all before this thing happen.
I had upload a video n hope u guys can give me more advise after viewing the video..
http://www.youtube.com/watch?v=c8Q0TsrZw-A
Old Mar 19, 2007 | 10:00 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
Yikes...that looks bad.
Does the gas coming out smell like exhaust?
The next step is to run a compression and leakdown test to confirm if the head gasket is bad.
Old Mar 20, 2007 | 10:26 AM
ivan323's Avatar
ivan323
U mean the smell coming out from radiator is it similar to exhuast?
I dun tink so ya..
Old Mar 20, 2007 | 11:54 AM
Provocateur
On permanent hiatus
I dun tink so ya..
Right. If the headgasket is blown, it will send combustion chamber gases into the coolant and the bubbles will smell like exhaust.
