b18c swap
Old Mar 13, 2007 | 01:45 AM
msala's Avatar
msala
Default b18c swap
I'm intalling a 95 gsr engine in my 92 what changes will I encounter with my wiring?
Old Mar 13, 2007 | 10:35 AM
2001TEGGSR's Avatar
2001TEGGSR
Is your 92 a GSR? If so it should be straight forward.
If not, you will most likely need to run wires to the ECU for Vtec, or use a different main harness.
Old Mar 13, 2007 | 04:25 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Moved to Engine Swaps.
Old Mar 17, 2007 | 01:12 AM
msala's Avatar
msala
Thanks man.
Old Mar 17, 2007 | 12:49 PM
project_hatch's Avatar
project_hatch
Power by Uncle Ben's Rice
invest in a gsr harness. well worth your time and investment. otherwise, the d series wiring harness won't work, you'll have to run vtec and knock sensor wires. And you'll have to repin some of your sensors. Well worth the $100 to buy a GSR harness.
