oil gauge....
Old Mar 3, 2007 | 04:58 PM
Redlinerz's Avatar
Redlinerz
Default oil gauge....
I am thinking on how to run my gauge line... has anyone used the greddy or blox ones? Or should I just tee off my oil pressor sensor? what do you think? I have also heard the greddy ones leak... rumor or true?
BLOX
Old Mar 3, 2007 | 08:47 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
I am using the Greddy one and have been for over a year. No leaks here. I would recommend a sandwich over a tee only if you plan on having more than just a gauge running off it. If you are only tapping for a gauge, just use a tee at the oil pressure sensor but avoid brass as it is soft and has been known to shear off inside the block.
Old Mar 4, 2007 | 12:35 AM
2001TEGGSR's Avatar
2001TEGGSR
If you opt to tap the OEM oil pressure sensor, take this article into consideration. http://www.theoldone.com/articles/oilpressure/
