Engine crankshaft
Old Mar 2, 2007 | 09:20 AM
ivan323's Avatar
ivan323
Default Engine crankshaft
Hi guys,
I wanted to check with u guys something.
If an example, my engine crankshaft n engine bearings had been damage b4 but will the problems arise even after i had change the re-con crankshaft n new bearings as well?
Do u guys recommend me to change another engine instead repairing by replacing it?
Is there any performance increase by using B20 crank on B18C?
Thank u for the all of u guys...
Old Mar 2, 2007 | 10:46 PM
2001TEGGSR's Avatar
2001TEGGSR
Originally Posted by ivan323
Hi guys,
I would not recommend using a resurfaced Honda crankshaft. If a bearing failure occurred once, it will more than likely happen again. Its also hard to find oversize/undersize bearings that will fit properly. Used crankshafts can be had for under $100 in perfect condition.
I believe the B20 & B18 A/B crankshafts are the same (slightly larger than a b18c). The B20 has larger cylinders to gain displacement.
In order to use an LS crank, you also need LS rods in conjunction with vtec pistons. This will give you a longer stroke and a gain in torque & horsepower.
Its probably cheaper for you to rebuild your current engine, just look for a used crankshaft. If you have any plans for modding, now is the time. Good luck!
