Pls bear w/ newbie quest: TURN SIGNAL not working
Old Oct 6, 2002 | 03:48 PM
caylan's Avatar
caylan
Default Pls bear w/ newbie quest: TURN SIGNAL not working
So I just took delivery of a blue 92 Civic Si w/ 152K to replace my beloved Black 92 Si (RIP-9/26/02 @162K).
Will post pixs tomorrow but I have some questions.
Since the previous owner was not as meticulous in care as I was there are some problems:
1) The driver door, on the inside, is ripped (Plastic part not cloth part)...What is the part number and where can I find a replacement for the interior panel of the door?
2) The left turn signal in the dashboard blinks 10x faster than right turn signal. basically the left blinker isn't working. I tried changing the bulb but it didn't solve the problem. So what is the problem?
3) What is the ashtray part number?
Thanks for any help on this!
Old Oct 6, 2002 | 04:11 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
http://www.hondaautomotiveparts.com/home.htm
Old Oct 6, 2002 | 06:53 PM
kinghawk's Avatar
kinghawk
as for the lights Id first double check to see if all the exterior lights work.... front and back if that checks out good check the groundings of the signals......... in the engine bay under the hood and behind the headlight there will be a white box with about 8 wires going to it ( black wires) loosen the bolt wiggle the bracket and bolt it back down that may also fix your problem
