Base Map?
Old Feb 4, 2007 | 04:00 AM
B16a2VTIguy's Avatar
B16a2VTIguy
Built B16a
Default Base Map?
I am trying to find a base map to start and dyno my build with, has anyone got one similar build that they could give me there base map?? (crome and its a p30 g01 ecu)
Looking to run 10psi for now (still using 2bar map and stock pump)
Heres my set up..
B16a1
JE forged 9.0.1 pistons
Eagle rods
T04e turbo (.57 trim .63 a/r)
440cc injectors
3" downpipe
2.5" exhaust
2.5" charge piping
38mm external wastegate
stock fuel pump for the time...have ordered a 255 walbro
stock FPR for the time....again have ordered one
Thanks ste
Old Feb 4, 2007 | 08:43 AM
Phantomhatch's Avatar
Phantomhatch
I got a map. sim. setup. moves out really good. if intersted in map pm email me at hondaruss@yahoo.com
Old Feb 4, 2007 | 11:56 AM
Snoopy's Avatar
Snoopy
been there done that
contact www.phearable.net and have them burn you something
Old Feb 5, 2007 | 12:45 PM
B16a2VTIguy
Built B16a
Has nobody got a similar set up we can at least use as a base map??or maybe someone who is really good with crome could make me one??
I need the car to get to wrk etc and i only wana run it up to 3k rpm whilst i get around, im gona leave the wideband plugged in whilst i drive to be on the safe side.
I am really desperate!
Thanks for any help
Old Feb 5, 2007 | 12:49 PM
Snoopy's Avatar
Snoopy
here's a directory of various maps: http://www.xenocron.com/bins/
be careful though. i would take the spring out of the wastegate to prevent seeing any boost until you have a full tune.
Old Feb 5, 2007 | 01:14 PM
B16a2VTIguy
Built B16a
Thanks for the help, unfortunatley cant see anything similar to my set-up.
Does anybody know if any of these will work for a upto 3k rpm limit???
On the maps we have made/ tried so far it seems to run really rich, and has a idle afr of like 12 which is the closest to 14.7 we can get too. if you try to put it under load at all, it goes to 9.2 -11.0????
Old Feb 5, 2007 | 01:18 PM
Snoopy's Avatar
Snoopy
try some of the tips in this article: http://importbuilders.com/tuningacar.htm
he's using hondata in that but it's similar to crome
Old Feb 5, 2007 | 04:56 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
I have a bin you could use that could get you around town. I am still running 10:1 compression and have 450cc injectors, but my turbo is a bit smaller. Open it up in crome and see what you think. Use at your own risk.
File Type: zip
Old Feb 9, 2007 | 04:07 AM
B16a2VTIguy
Built B16a
thanks
Old Feb 10, 2007 | 04:04 AM
B16a2VTIguy
Built B16a
Thanks for all the help, turned out it was a bad vaccum seal.
But the map shmoo gave ruled out the possibility of my bad mapping.
