broken screw
Old Feb 2, 2007 | 11:46 AM
mikeybaby's Avatar
mikeybaby
Default broken screw
Hi i have a water pump that has a broken screw end in it. It is the kind of screw were it goes from fat to skinny and I have no clue how to get it out. would anyone be able to give me any tips?
Old Feb 5, 2007 | 11:57 AM
mikeybaby's Avatar
mikeybaby
any onee i have read the tips on getting out a broken screw but this one is harder because it is in such a small space
Old Feb 5, 2007 | 04:50 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Do you have pictures?
If it is still drivable, see if a machine shop could help you extract it. Otherwise, remove as much as you can from the driver's side near the bolt and see if you can extract it yourself.
Old Feb 5, 2007 | 06:58 PM
mikeybaby's Avatar
mikeybaby
What happened was I was taking off my power steering pump and the bolt broke. I will get pictures up soon, but if I take it to a local machineist shop how much you think that would cost around. Alright thanks.
Old Feb 5, 2007 | 08:09 PM
2001TEGGSR's Avatar
2001TEGGSR
So which bolt broke? The power steering mounting bracket bolt?
You can get a bolt extractor from sears, they work just fine.
Old Feb 5, 2007 | 08:13 PM
mikeybaby's Avatar
mikeybaby
yeah you no how their are the 2 bolts that are used to mount it they are the long screws that go from fat to thinner. one of the ends of them broke you think that would work?
Old Feb 5, 2007 | 08:46 PM
2001TEGGSR's Avatar
2001TEGGSR
Yes it will work, Got the idea?
They sell them at Sears. I would order a new bolt from Acura, just be sure not to snap it again.
Lefty Loosey, Righty Tightey.
