help for my wife !!!!!!!11
Sounds like a simple "change the tranny fluid" solution isn't going to help. I dunno whether you're car savy or not but I would take it to someone who can fix/replace your tranny cause it sounds like it's done.
It sounds like the idle air bypass valve. On the back of the intake manifold it looks like a real tiny cylinder thing that bolts near the throttle body. As far as the transmission slip, you might have too little fluid. I would take it to a reputable transmission shop and have them take a look. Good luck
ok guys i decoded my check engine light manually and this came out
alrite bro i found it and i did the thing with the paper clip
the first time the light did 7 blinks
second time 9
then i wait a lil longer and the light stayed on for few seconds and began again
this time was
first 4 times
second 7 times
third 9 times
I read the manual and it says that the code 4 is the CRANKSHAFT POSITION 9CKP SENSOR)
7 is the THROTTLE POSITION SENSOR (TP SENSOR 0
9 is THE NO.1 CYLINDER POSITION (CYP SENSOR)
NOW MY BIG QUESTION IS CAN ANYONE TELL ME HOW TO FIX THIS SENSORS ???????thanks a lot
second time 9
this time was
first 4 times
second 7 times
third 9 times
