Question about fuel pump
Old Jan 30, 2007 | 04:03 PM
medvec04's Avatar
medvec04
Default Question about fuel pump
Is my stock gsr fuel pump going to be ok for 250whp?
Old Jan 30, 2007 | 05:11 PM
dubcac's Avatar
dubcac
I
If you run low pressure it will be fine...I'm assuming you're going turbo. If you are using a boost dependent FMU, get a high pressure pump. With larger injectors and a tunable EMS, the stock pump is more than adequate. It loses its efficiency as the pressure goes higher. If for some reason you are running an FMU like with a drag/revhard stock kit, I would ditch that altogether.
