need help with abs please!!!!!!
Old Jan 18, 2007 | 04:17 PM
Ill-Will's Avatar
Ill-Will
Default need help with abs please!!!!!!
I've got a 94 honda accord and the abs light stays on when I turn the car on. The shifter is stuck in park and I cannot move it unless I manually use the key to unlock the shifter. Park and reverse work fine but when I put the car in D4 the light on the dash doesnt light up and there is no power when I try to go, same thing with D3 but it goes normal speed in reverse. Is this a safety feature with the ABS? I tried to read the code but I have a 6 pin connector under the glove box and tried every combination to get the ABS light to blink but it would not. I am stuck and need help please any solutions.
Old Jan 24, 2007 | 04:16 AM
project_hatch's Avatar
project_hatch
Power by Uncle Ben's Rice
helms/chilton manual is probably your best bet here...there are ALOT of ABS problems/solutions
Old Jan 24, 2007 | 07:05 AM
JimBlake's Avatar
JimBlake
I don't think it's an ABS safety 'feature'. Sound like 2 or more unrelated problems.
There should be a 2-pin connector over at the right kick-panel, it's a blue plastic plug. Jumper that to check codes. If it's never been used it might still be taped up to the harness. In my Integra it was in a green rubber holder.
Helm manual (www.helminc.com) is way better than Chilton.
Shifter stuck in Park might be the brake interlock. Do your brakelamps (in back) work? If not, check the switch on the brake pedal. That releases the shift lever (in addition to controlling the brake lights).
