What will i need?? bOOst Q
Old Jan 18, 2007 | 10:45 AM
B16a2VTIguy's Avatar
B16a2VTIguy
Built B16a
Default What will i need?? bOOst Q
I am just finishing building a Boosted B16a2 build, i want to run around 15psi of boost on my set up-
*JE forged pistons 8.5 compression and eagle rods
*ARP bolts all round
*OEM 0.4 headgasket
*T04e (.57 trim and .63 a/r)
*2.5" charge piping
*3" downpipe
*RC 440 injectors
*Mapped with crome
Will i need more to run this amount of boost, like bigger fuel pump, bigger injectors, and a 3 bar map sensor?
Old Jan 18, 2007 | 10:56 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
You will need larger injectors (at least 550's, probably more), a larger fuel pump (Walbro 255lph should suffice), and a 3 bar MAP.
Old Jan 18, 2007 | 11:08 AM
B16a2VTIguy
Built B16a
Everything i expected then, damn!
So out of interest, untill i get those parts whats the most boost i can run??
Old Jan 18, 2007 | 11:15 AM
Provocateur
On permanent hiatus
Depending on how much fuel pressure and duty cycle you are running, you can run up to ~12 psi on the stock MAP sensor, but I wouldn't run that much without at least upgrading the fuel pump.
Old Jan 18, 2007 | 11:17 AM
B16a2VTIguy
Built B16a
Ok thanks for the info.
Old Jan 18, 2007 | 11:58 AM
18crx's Avatar
18crx
stock booster
do you have a fpr if not only run 7-8 ish until u get a new pump, ur stocker will die if turned up to much.
Old Jan 26, 2007 | 02:52 PM
B16a2VTIguy
Built B16a
Thanks for the info, i will invest in a new fuel pump. i will get a walbro 255.
Old Jan 26, 2007 | 03:10 PM
Snoopy's Avatar
Snoopy
been there done that
make sure to get the hp version
Old Jan 29, 2007 | 10:17 AM
B16a2VTIguy
Built B16a
I didnt realise ther were any differant versions but i then again i havent researched them yet, i will make sure to buy the HP version thought, thanks again. ste
