Weird whining noise from under hood
Old Jan 15, 2007 | 01:30 PM
Roadrage's Avatar
Roadrage
Deebo
Default Weird whining noise from under hood
When i start my car up she starts to whine..or squeal, but when the car is warmed up then she seems to be fine. I want to say its the belts but when i check them they are tight and snug..any suggetions on what it may be. It is a 01 accord sedan dx model. Thank you in advance
Old Jan 24, 2007 | 06:36 AM
Phantomhatch's Avatar
Phantomhatch
Alot of the times i have seen the ALT make noise just as mentioned . i noticed my old crx doing it when it was cold a sure sight fo me to change the alt when glad i did cause it was alittle rough
Old Jan 24, 2007 | 07:10 AM
JimBlake's Avatar
JimBlake
Put some belt dressing on the belts. Or even spray some water on them. If that makes any difference, you know it's time for new belts.
Even tho they look good, old belts get hard & 'slippery'. Don't over-tighten them (to stop slipping) because then you tear up alternator bearings, etc.
Old Jan 24, 2007 | 11:31 AM
project_hatch's Avatar
project_hatch
Power by Uncle Ben's Rice
do NOT put belt dressing on it. replace the belts if you haven't in the last 10k miles, they're cheap and i'll save you the headache
Old Jan 25, 2007 | 08:22 AM
JimBlake's Avatar
JimBlake
Originally Posted by project_hatch
do NOT put belt dressing on it...
Not for a permanent fix, anyway. I suggested it as a way to show whether the belt was responsible for the noise. Belt dressing sorta works OK but not for long. You have to keep using it more often as the belt hardens with age & that's just not a good idea.
Old Jan 28, 2007 | 04:57 PM
Roadrage's Avatar
Roadrage
Deebo
Thank you fellas
