GSR block on Si Head
b16 and type r heads share the same pr3 casting. type r heads though have a mild p&p, and upgraded cams and valvetrain.
gsr heads are a p72 casting and have different valve entry angles, different bolt pattern for the intake manifold, and has a smaller combustion chamber for .3 more compression points.
all heads these are interchangeable with each other.
