EG civic hatch
Old Dec 31, 2006 | 05:16 PM
  #31
TotalVelocity's Avatar
TotalVelocity
So koni is a ghood brand?? what is GC/?
Old Dec 31, 2006 | 05:18 PM
  #32
Snoopy's Avatar
Snoopy
been there done that
ground control coilover sleeves with koni yellow shocks. a great setup for the money. check www.weaksauce.org for deals
Old Dec 31, 2006 | 05:20 PM
  #33
TotalVelocity
What abou tcambers and lower a arms and stuff.. strut bars all that and should i get integra type are spindals for the 5 lug set up or are tere better conversions?
Old Dec 31, 2006 | 05:30 PM
  #34
Snoopy's Avatar
Snoopy
camber kits are needed if you have more than a 2'' drop. control arms are not needed unless you want some bling factor. strut bars and whatnot dont make a noticeable difference. but if you must get one, try to find a 3 point bar like benen, carbing, or passwordjdm.
for the brakes, i would just convert the rears to disks and get better pads and fluid.
Old Dec 31, 2006 | 05:36 PM
  #35
TotalVelocity
OEM honda can handle the power????
Old Dec 31, 2006 | 05:41 PM
  #36
Snoopy's Avatar
Snoopy
not the pads. that's why you get more aggressive pads and fluid with a higher boiling point. the axles are fine too. unless you like dumping the clutch at 8k during your launches.
Old Dec 31, 2006 | 05:45 PM
  #37
TotalVelocity
if you do that you wouldnt go anywhere if you have 350whp
