90 crx swap question
Old Dec 15, 2006 | 10:54 PM
89crxinprogress's Avatar
89crxinprogress
Default 90 crx swap question
just curious if it is possible to pull the engine without pulling the tranny.... i was looking at it today and it looks like the pulleys may hit if i tried it that way... i know it would probably be easier if i pulled the tranny, but i really don't feel like taking the axles off and such... so is it possible without removing the pulleys or do i have to remove them to pull the motor this way?
thanks in advance.
Old Dec 16, 2006 | 07:52 AM
89crxinprogress
no body..... come on someone.... help a brother out>>>>> please
Old Dec 16, 2006 | 12:19 PM
Snoopy's Avatar
Snoopy
been there done that
if you pull the engine but leave the tranny it's only gonna have the one mount supporting it. pull them both at the same time. it'll be much easier.
Old Dec 17, 2006 | 10:24 AM
18crx's Avatar
18crx
stock booster
just pull it all out its easier. . undo axle nuts lower ball joints axles outa tranny wire harness from main harness fuel return and supply clutch cable throttle cable radiator hoses from fire wall and rad speedo cable clip. shift linkage exhaust and motor mounts oh the wires for the fan and remove the rad i think thats about it. oh and if ur batterys in the front ull have to remove it and the bracket it sits on.
Old Dec 20, 2006 | 08:32 AM
89crxinprogress
thanks guys swaped it out over the weekend.... but the i am missing the wire that clips into the starter... is it not part of the wiring harness... i have searched every damn place and it is the only one keeping this bitch from running.
Old Dec 20, 2006 | 11:25 AM
18crx's Avatar
18crx
stock booster
it should be right around where ur therostat wires are and with the ones on the head sensors.
Old Dec 22, 2006 | 06:07 AM
89crxinprogress
yeah i found it... i had to look at my crx to find it but i found it.... it was rapped around his harness and blended in really well.... so now everything is hooked up and it runs really well... not to shabby for my first install.... thanks for your help guys...
