Which Software are you guys using
Old Dec 6, 2006 | 01:58 PM
TLRide's Avatar
TLRide
Default Which Software are you guys using
Just wondering whose software you guys are using to read and reset codes, diagnose etc. I plan to hook up my notebook via USB link to my '99 TL.
Thanks,
TLRide
Old Dec 11, 2006 | 12:17 PM
mberndt's Avatar
mberndt
Thanks,
TLRide
On most H/A's the codes can be "read" through the flashing of the Check Engine Light... One flash = Code one, and so on...
To reset them, you must fix what is throwing the code, then reset the computer by pulling the power to it by either disconnecting it, or pulling the back-up fuse...
I'm unsure of 99 Acura TL's but for my EG I had to install my own USB cable into my ECU in order to Datalog and use a notebook with it.
