Swapping in a 99 EX
Old Dec 6, 2006 | 05:33 AM
uo959's Avatar
uo959
Default Swapping in a 99 EX
Hey guys,
I was going to swap my engines. About how much hp would I be looking at with a b16a swap, turbo, full exhaust, and CAI?? Should I go with a different engine?? I was deciding between H22a, K20a, b16a, and b18c. What is the aftermarket like on each of these??
Old Dec 6, 2006 | 07:24 AM
Snoopy's Avatar
Snoopy
been there done that
aftermarket is plentiful for each. i suggest you keep researching after you said cai after turbo. :a:
go with a b18c1. a b16 will be piss slow in your ex until you boost.
Old Dec 6, 2006 | 02:42 PM
uo959's Avatar
uo959
Why not a K20 or H22??
Old Dec 6, 2006 | 06:54 PM
Snoopy's Avatar
Snoopy
if you have the $8k+ necessary for a complete stock k20a swap, go for it. h22's arent a direct bolt in.
Old Dec 8, 2006 | 05:07 AM
uo959's Avatar
uo959
http://www.jdmracingmotors.com/index...rs&motor_id=32 It's not $8k.
Old Dec 8, 2006 | 07:30 AM
Snoopy's Avatar
Snoopy
Originally Posted by uo959
that's just the engine. after buying everything else needed for the swap, mounts, axles, wiring, kpro, etc., thing's add up quick.
Old Dec 8, 2006 | 08:24 AM
uo959's Avatar
uo959
OH! what do u think I should go with snoopy??
Old Dec 8, 2006 | 08:39 AM
Snoopy's Avatar
Snoopy
dot
Old Dec 9, 2006 | 12:36 PM
uo959's Avatar
uo959
So, are you saying a b16 is a bad idea?? If h22 is not straight bolt in is that not good or is it just not easy?? There doesn't seem to be much aftermarket for the b18. how do I search for aftermarket for a 99 Ex swapped b18??
Old Dec 9, 2006 | 01:05 PM
jdmeg6hatchy's Avatar
jdmeg6hatchy
i
An H22 in any 88-00 civic is going to be a much more dificult swap as opposed to any b16 or b18. I agree with Snoopy, id go with the b18c!
