wtf... this timing belt is a joke.
Old Oct 2, 2002 | 07:41 PM
aut0tek's Avatar
aut0tek
Default wtf... this timing belt is a joke.
Okay... Let's start from the beginning...
I'm ATTEMPTING to do LS/VTEC... B18a block, with b16a1 head.
Along with tons of internals but that won't matter...
I tried putting the timing belt on all last night and most of tonight... to no success... every time I put the belt on it looks good... then when I turn it a few times to see if it's still on it's retarded by a half of a tooth or so... which is roughly 8-10 degrees.
Well, I tried tonight and I said **** it I'll advance the cams a little and leave slack on the front and see what happens.
Well it worked good... except it's the exact opposite as before... they are advanced about 8-10 degrees.
Also, with all the slack out, and the tensioner tightened... And having been turned in the right direction... if u stop at TDC and look at the cam gears, they are not a whole tooth off... As in, if I could simply pick the cam gears off, and turn them one tooth (which would be the only way I could do... unless I just decided to go more than 1 tooth)
It would be like I said before, retarded about a half of a tooth.
What in god's name have I done wrong?
Harry
Old Oct 2, 2002 | 08:08 PM
dubcac's Avatar
dubcac
I
Use an ITR timing belt.
Old Oct 2, 2002 | 08:39 PM
Snoopy's Avatar
Snoopy
been there done that
use vtec timing belt with vtec water pump.
Old Oct 2, 2002 | 09:13 PM
aut0tek's Avatar
aut0tek
Okay... what's the diff. in the water pumps?
And what's the diff. in the timing belts?
Harry
Old Oct 2, 2002 | 09:17 PM
aut0tek's Avatar
aut0tek
Btw, my theory is correct, right?
i.e. if all the tension is taken out of the timing belt in all places, there is NO WAY POSSIBLE to have less than 1 tooth off in timing, correct?
Harry
Also, dubster: can a b16a belt do or does it hafta be ITR and nothing else? ;-)
Thanks again guys,
Harry
Old Oct 2, 2002 | 10:13 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
Your timing belt has to match whatever water pump you're using.
Old Oct 2, 2002 | 10:20 PM
aut0tek's Avatar
aut0tek
ok so if I have an LS water pump why my LS timing belt not working? lol And why would a VTEC timing belt be the key? I really don't want to get a new water pump. :-(
Old Oct 3, 2002 | 11:38 AM
preylude99's Avatar
preylude99
thats a common thing people run into with hybrids..... a lot of mixing and matching until you finally find everything that matches correctly...
Old Oct 3, 2002 | 08:10 PM
-KangaRod-'s Avatar
-KangaRod-
Captain
you should buy the new water pump and timing belt..its only $100, and if you are concerned about $100 and you are putting your LsVtec together, you're in trouble.
Old Oct 3, 2002 | 09:44 PM
aut0tek's Avatar
aut0tek
Thanks everyone... I got it in time... Right on the money. For some reason I was thinking the "up" mark on the cams would be point STRAIGHT up at TDC when in reality they are turned slightly... And that's the way mine are. I didn't see the mark in between the cams... I'm used to the old B18a with 3 bigass arrows that say: "HERE DUDE YOU DID IT RIGHT"
So basically all that fussing was over nothing. :-(
Thanks for all that helped,
And Kangarod: I've spent well over that much in my rods alone... but thanks for the heads-up ;-)
Harry
