95 gsr idle problem!!!
Old Dec 4, 2006 | 05:18 PM
bdjimz's Avatar
bdjimz
Default 95 gsr idle problem!!!
i have a 95 gsr integra and for some reason it is idleing at 1500, and it just all of a sudden at a stop light the car dropped and raised the idle from 1000 to 2000 the whole time i was at the light. Please Help
Old Dec 4, 2006 | 09:52 PM
1stGenCRXer's Avatar
1stGenCRXer
GWAKS- Tech Geekifier
Sounds like a vacuum leak.
If not that, your IAC valve may be due for cleaning.
-Harry
AIM: NDcissive
Old Dec 5, 2006 | 04:37 PM
mberndt's Avatar
mberndt
U could be another victim of the elusive vacuum leak...
My buddy had similiar prob...
Was a vacuum leak not in the lines, but around the brake booster seal, causing a rolling idle from 1000-like 2000 rpms.
Old Dec 14, 2006 | 02:07 PM
civic401's Avatar
civic401
Get brake fluid and spray it on your lines were there is vacuum and on your intake manifold were the gasket are located at while the car is running. If you here the motor change sounds then that’s were your leaking at.
Old Dec 14, 2006 | 11:34 PM
1stGenCRXer
Originally Posted by civic401
Get brake fluid and spray it on your lines.
NO NO NO NO NO NO NO! Brake fluid does all sorts of VERY BAD things when you use it outside of the brake system! It eats paint, it rots rubber lines that are not specifically designed to be in contact with brake fluid, and Dot3 fluid is EXTREMELY FLAMMABLE!
A MUCH safer method is to use a non-flammable carb/choke cleaner. Rather than the engine gaining RPM and potentially damage it due to detonation, the engine will choke out (or at least lose some RPM) if you spray it at a vacuum leak source.
-Harry
AIM: NDcissive
