tune up at home.
Old Oct 2, 2002 | 02:01 PM
LocaL raCer's Avatar
LocaL raCer
R.I.P. Kato-san
Default tune up at home.
can someone tell me what i need to buy, or give me a link to a site that has a list or anything? TIA.
Old Oct 2, 2002 | 05:44 PM
AwwsChwA's Avatar
AwwsChwA
Default Re: tune up at home.
for a general tune-up? Depends on how many miles you have on it. The standard things to replace are spark plugs and plug wires (if the wires are original and you have 50,000+ miles), fuel filter, and possibly the distributor cap/rotor, if they need replacing. Also, check for cracking fluid hoses and such.
Adjusting the valves is a good idea as well. Should be done every 15,000 miles or so. Oil change, possibly the air filter, and maybe give the vacuum systems a once-over, make sure all the hoses are in good shape.
Old Oct 2, 2002 | 05:45 PM
LocaL raCer
R.I.P. Kato-san
thank you. :thumbup:
Old Oct 2, 2002 | 05:56 PM
AwwsChwA's Avatar
AwwsChwA
any time, my friend
oh, and in regard to the air filter. You've probably heard of the K&N air filters. If you can afford it, buy one. They're the best 50 bucks you can spend on a single part for your car. You'll get better mileage, a small but noticable gain in performance, and they're washable. Never replace a filter again
Old Oct 2, 2002 | 06:18 PM
LocaL raCer
R.I.P. Kato-san
ok. will do. thanks again man.
Old Oct 2, 2002 | 07:28 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
change that tranny fluid also...
Old Oct 2, 2002 | 07:30 PM
LocaL raCer
R.I.P. Kato-san
okie dokie.. wow long time no see dood... hows your car???
Old Oct 2, 2002 | 07:42 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
It's fine, still running. I got a spare block in case something breaks. Or, I might just build it, swap it in and run more boost. Money is the limiting factor, of course.
Old Oct 2, 2002 | 07:50 PM
LocaL raCer
R.I.P. Kato-san
sounds good as always more boost = yummy..
Old Oct 4, 2002 | 09:02 PM
seth90dx's Avatar
seth90dx
I created a post in I belive this forum (might be the hybrid forum) called PREVENITIVE MATANACE! You might want to check it out! If you have something to add please do so
