what do i need
Old Nov 11, 2006 | 07:12 PM
fatboycivic's Avatar
fatboycivic
Default what do i need
i have the ls motor and would like to put the gsr motor in it my car is a 1990 i know i need the obd 1 wire conversion kit and the head and block and ecu but do i need any thing else plz help and will my check engine light stay off
Old Nov 13, 2006 | 05:36 AM
primetime's Avatar
primetime
you need the gsr motor mounts, the gsr engine wiring harness, gsr axles, gsr injectors, In short you need the entire motor! you shouldn't get a check engine light unless there is something wrong with the motor.
Old Nov 13, 2006 | 03:43 PM
fatboycivic
thank you very much hopefully this wont be to difficult
i can still use my current ls tranny with the cable clutch right?
Old Nov 13, 2006 | 05:53 PM
Snoopy's Avatar
Snoopy
been there done that
you can use the ls tranny, but why would you? acceleration will suck with it.
Old Nov 14, 2006 | 09:14 AM
primetime's Avatar
primetime
if you can't afford a gsr, type r, or b16 tranny then use your LS tranny untill you can afford those trannys
