gsr hatch problems
Old Sep 21, 2006 | 11:09 AM
tommyhcky13's Avatar
tommyhcky13
Default gsr hatch problems
just got back from nopi in atlanta and my car ran like crap the whole way there. so i have some questions. i get the worst gas mileage on the street maybe 15mpg, but on the highway maybe like 25mpg. everytime i touch the gas a huge cloud of smoke about suffocates the person behind me and my back bumper is covered in sut. i burn oil like you wouldnt believe. i changed the valve seals not too long ago but that didnt fix it. the kid who had the car before me bored it out and i think that may be the oil problem but im not sure. if anyone knows whats goin on please help. motor is a 95 gsr with 81.5 high compression pistons, aem fuel rail and fpr at 40lbs idle. walbro 255 fuel pump, and 355 injectors
Old Sep 21, 2006 | 12:41 PM
Snoopy's Avatar
Snoopy
been there done that
do compression and leakdown tests. sounds like it's running really rich too.
Old Sep 24, 2006 | 04:08 PM
tommyhcky13
checked compression 11.5 across the board. fixed fuel pressure turns out it's supposed to be 40lbs full throttle, need to get a new distributor i think, thanks for your help
Old Sep 24, 2006 | 06:11 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
You obviously didn't check your compression because 11.5 is not a valid compression result. You are looking for a psi number.
Old Sep 25, 2006 | 09:10 AM
tommyhcky13
no the guy checked it and said that the psi was equal to 11.5
Old Sep 25, 2006 | 12:35 PM
Snoopy's Avatar
Snoopy
do it yourself. not that hard. you're looking for the psi number for each individual cylinder.
Old Sep 25, 2006 | 12:57 PM
Provocateur
On permanent hiatus
If it were 11.5 psi in any cylinder, it wouldn't be running. You are looking for 250+ psi per cylinder if your compression ratio is 11.5:1.
Old Sep 27, 2006 | 07:16 AM
mberndt's Avatar
mberndt
Agreed. Who did your Compression Test?
Old Sep 27, 2006 | 09:39 AM
tommyhcky13
the guy checked it because i dont have a gauge. he said the compression was good 11.5:1
