97 ex ecu?
Old Sep 20, 2006 | 04:44 AM
civic-rcr's Avatar
civic-rcr
Civic Racer
Default 97 ex ecu?
can i chip a 97 ex civic? or do i need a new computer?
Old Sep 20, 2006 | 05:38 AM
Intege_92's Avatar
Intege_92
BAD ASS TEXAS BOY
im Pretty Sure You Can Chip A 97' Ex Ecu. I Dont See Why Not !! Or You Can Swap Your Ecu For A Gsr Or Sir Ecu
Old Sep 20, 2006 | 05:48 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Chip it for what? Like a cheap-o mod chip seen on ebay or something like crome or hondata?
Old Sep 20, 2006 | 07:13 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
It is OBD2...you cannot chip it. If you have ever looked inside of an OBD2 ECU, you will see why.
Old Sep 21, 2006 | 02:18 AM
civic-rcr's Avatar
civic-rcr
Civic Racer
Default ecu
so i can just replace my ecu with a gsr, ls ecu and notice a difference?
is it just a plug and play or do i need to do something else after i get a different ecu.. and is it safe? no damage to the car?
Old Sep 21, 2006 | 06:36 AM
t3t4delsol's Avatar
t3t4delsol
you probly have a p28 in your car now, if your car is a a 97 then it is obd2a. Obd2 computers can not be chipped, as far as you asking if you can put i ls or a gsr computer in there known as p72 the answer is no, they will not contain the correct fuel and timming maps that your motor needs
Old Sep 21, 2006 | 03:12 PM
Provocateur
On permanent hiatus
You will notice a difference, but it will probably run worse. Keep your ECU stock until you have a good reason to have it tuned. This isn't Gran Turismo where you pay 100 credits and get 12 hp from an ECU chip.
For a stock motor, there is no other ECU that will make it run better than the one you already have.
