the best engine for turbo?
Old Sep 15, 2006 | 10:35 AM
450rking's Avatar
450rking
Default the best engine for turbo?
what i want to know is what is the best engine for a turbo i want to get 250 + whp i like the h22a engine but i have herd that thay have weak blocks i am also considering the 2.3 and the b18
Old Sep 15, 2006 | 12:57 PM
Snoopy's Avatar
Snoopy
been there done that
any b18a/b/c. easy to swap into a civic and can take 250+whp on the stock block.
Old Sep 15, 2006 | 01:37 PM
Omniscient's Avatar
Omniscient
warm butter on toast
Pretty much every honda motor can handle a turbo, it's just that some have their weak points. B16As have high compression, B20s have siamese sleeves, H22s have fmr sleeves.
The best bang for the buck with turbo would be a B18b in my opinion. You can get a full motor swap for like 750$ and can make 250whp easily.
Old Sep 19, 2006 | 05:49 AM
RZFD's Avatar
RZFD
Screamo Negro
By "Stock Block" I mean: Stock block, rods, pistons...ect. Stock below the headgasket
B series:
B18C, LS/VTEC:
1. crx=si 605hp, 364tq stock B18C1 TO4R at 26psi Crome-pro with traktek 110
2. stOOpid tuned 523whp on 22psi and a 50 on C16. All stock B18C1 (11.00 @ 133)
3. C squared motorsports 518whp 324tq 20lbs on C16 and PT67
4. fuccarlos 508whp 361tq @17psi on c-16 (10.40@136 1.5 60')
5. marco B18C1/B16 head 480whp @ 23/24 psi on C16 tuned by jason hunt
6. GodFather of Boost 470 on c16 @20-21
7. ngogsr 462.52 fwhp 320.87 tq 23psi c 16
8. cyph3r 454whp 317tq sc61
9. carchitect 424whp 271tq Stock B18C5. Precision SC63
10. philipwight 400whp 260tq on stock gsr on pump gas (11.3@131)
B16:
1. Randys 630whp and 390tq on 118. (10.97@131)
2. redline130 393 whp 261 ftlbs, C16 (11.65 @ 125mph)
3. marques4130 350 whp sunoco 112 best (11.8 @ 119 @ 4200 ft)
4. 98gsrTEG 344whp@1 bar on pump gas
5. Black SI 344whp on a stock b16 @14psi
6. 99B16Si 333whp/221wtq SAE at 13psi SC61
7. integlspwr2k 330whp on a stock head stock block
8. Bryson 329whp 210tq 13psi SC61 on 91
9. G"UNIT 329whp 207tq @12psi on a sc61 on 93 octane
10. s2kkk (Jeff Evans tuned) 325whp/215tq
LS:
1. Rico 340whp 270tq 1.7 bar on a stock LS
2. JDMH22HATCH 340/270 15lbs stock LS
3. adseguy 328whp 269trq 16PSI on 93 octane. T3/T4e .63/.60 57 trim
4. Jeff Evans tuned 320whp/290tq
5. M.A.R.C 315whp/280wtq @ 15psi on 93oct
6. efgarage 308whp 287wtq 15psi 91 oct,tuned with neptune
7. gpomp 308 whp, 255 wtq 94 octane
8. ramrod 307 whp, 247tq Crome pro
9. civicflnum1 303.4whp and 269.4wtq @ 14psi t3/t04e 60 trim 93 octane
10. sean 302whp/280tq @ 16psi sc61 on sunoco 94 octane (11.8@116)
F20C
1. TURBO-TEG 690 hp stock s2000 motor with 30 psi on a T-76 Update 4/21/06 (cracked sleeve)
2. JG-fabrications 590 whp 396 wtq (c16)
3. Tinker219 469whp 301tq 16psi GT4088R
4. Sideways 450rwhp 260ftlbs @ 13 lbs boost
5. Jeff Evans tuned 448whp/273tq stage 3 gt FR kit, 15psi,
6.
7.
8.
9.
10.
F22:
1. twkdCD595 f22b1 335 whp 279 ft. lbs
2. bigdaddyvtec F22b1 10 PSI- 273 HP 275 TQ
3.
4.
5.
6.
7.
8.
9.
10.
K series:
1. Sir2egk 646.90whp / 522.40tq @ 7600rpm GT35R K24 block/stock K20A2 head (11.2 @ 125)
2. dc5_rsx 560 whp/392 Tq
3. Stoopid tuned 515whp bone stock K20A2
4. Jeff Evans tuned k24a 15psi-440whp/300tq
5. DDD 409.38whp 294.76 tq @ 11-12psi 94
6.
7.
8.
9.
10.
H series:
1. This One (Stoopid tuned) 536whp bone stock H22A
2. This One 442whp bone stock H22A
3. Tyler H H22A- 411.3 hp, 330.2 ft-lb (11.076 @ 126.57 mph)
4. trickeng 404wHP completely stock internal H22A
5. 404wHPunder_OATH 363 whp 278 wtq
6.SpeedingHatch 354whp 303ft/lbs Lasted 2.5 months ( )
7. x-1 H22 Mased at 344whp
8. C61lude's made 328.2hp on 10psi, onefab mani sc61
9.Jeff Evans tuned H22a 300whp/245tqn 8psi FR stage 1 GT kit
10.
D series:
1. Jeff Evans tuned D16z6, 308whp/262tq, neptune, GT28RS
2. BoostedED9 D16Z6 302whp 251wtq
3. LurkerS8 300whp 237tq
4. nerdsports Y7block/Z6head 273whp 224tq
5. King-Kong D16z6 @ 264p/240ft.tq @ 13 psi sc50
6. ladysman 262whp on 12.5 psi stock Z6
7. wilham320 d16y8 w/ greddy kit at 15psi - 252whp pump gas
8. turbozxi 250whp 250 TQ stock zc sohc IHIvf22 with around 15psi
9. Blind Fashion 236whp 189tq stock Z6 243000 miles!
10. TheShocker d16a6 231 WHP 206 TRQ t3/t4 60 trim .63 a/r 9 psi
Old Oct 1, 2006 | 09:50 PM
rage469's Avatar
rage469
3rd gen h22 has a closed block which is more reliable for turbo but in my experience a boosted b18a/b is the best bang for the buck. Make sure to tune though. Mine ran 11.6 @126 on a built bottom end. I blew up the rings on the stock internals with 12 lbs.
Old Oct 2, 2006 | 03:44 PM
descivic's Avatar
descivic
dude any of honda's engines can get you what you want, shit My EG civic on D16z6 is pushing upwards of 238 HP on stock internals, and Im having ZERO problems out of it.. Make sure if you are running a D you have that shit tuned right, or Bye Bye D
