Need a harness....
Old Sep 28, 2002 | 05:01 PM
ASIMO's Avatar
ASIMO
Default Need a harness....
I went to h22a.com and they say that they have the H22 and all the stiff. but they say thet it comes with the harness (cut at the wall)
I don't want to have to splice all the wires back together. does anyone know where I can get a FULL harness?
Old Sep 30, 2002 | 09:31 PM
fastludeh22's Avatar
fastludeh22
how much are these harness's worth, i might be able to get one, but im not sure what he wants for it
Old Sep 30, 2002 | 09:59 PM
ASIMO's Avatar
ASIMO
I dont know what they run. but I need to update this pot. I got a harness. Thanks anyways. and I got it for $0.00 so I still dont know what they cost.
Old Oct 1, 2002 | 11:50 AM
wadzii's Avatar
wadzii
fear the dark side
normally when you do a swap you use the harness from the car you are putting the motor in......
preludes have a 2 piece harness, the part that goes through the fire wall is tied into the dash harness
Old Oct 3, 2002 | 11:56 AM
ASIMO's Avatar
ASIMO
HUH??????
Old Oct 3, 2002 | 02:12 PM
wadzii's Avatar
wadzii
fear the dark side
you DO NOT NEED A HARNESS..... when you take the motor out of your car put the harness from the STock motor on the h22.
Old Oct 4, 2002 | 06:46 PM
ASIMO's Avatar
ASIMO
But then you have to go throught the crap of adding the extra wire and pin for the VTEC in the harnes for the H22 ECU. WHy not just use the harness fron the H22 that already plugs right tinto the H22 ECU?
Old Oct 6, 2002 | 05:32 PM
wadzii's Avatar
wadzii
fear the dark side
the harness that is on the ENGINE does not plug into the ecu. it plugs into the DASH harness. the dash harness goes through the firewall where it plugs into the engine harness at the shock tower.
Old Oct 9, 2002 | 10:46 PM
ASIMO's Avatar
ASIMO
I guess I'll just have to see and look when I do the swap cuz what you just said wne WAY over my head.
Thanks for the help anyways.
Old Oct 10, 2002 | 05:16 PM
slow_civic's Avatar
slow_civic
does h22a.com sell usdm engines, or are 97-01 JDM engines OBD-II
