ls/vetc vs type r which one is faster
of course half way through building these motors i realized the golden eagle conversion kit was a complete waste of time!! Dropping in the LS crank and Ls rod (stock or forged) is going to give you an LS/vtec without all of the hassle.
but to get back on the subject depending on the head that you "slapping on", you are going to get different compression results!! p72 are better for all motor ls/vtec and pr3 and itr heads are better for turbo applications!
Nobody said it was just slapping a vtec head onto a block, obviously changing over to vtec head studs, using the golden eagle ls/vtec conversion kit, changing the crank and rod bearings to gsr bearings etc., etc., etc. Of course this is long, and expensive way of doing it! i've built about 15 or ls/vtec motors for people and i can tell that they are very capable of eating type r's alive!!!
as far as tossing a LS crank and rods into a gsr or type-r you are not going to gain much, i personally would rather go this route because i like the C-type blocks due to their effcient oil design, but when it comes down to it most high horsepower applications where you are going to be replacing most major components you don't need the oil squirters and it jsut comes down to the ideal equations of what will be the cheapest-- in most cases it's finding a intact p72 or pr3 head and the use of a cheap LS longblock
when it comes down to ls/vtec there is alot of stuff you need to know about the motors, and most people just don't take the time to research
compression will be raised due to a number of factors, one not normally thought about is the fact that the LS deck height is slightly lower than the deck height of the c series blocks-- this actually increases compression a good bit.
for example:
a stock ls block and rotating assembly mated with a p72 head will yeild a higher compression than a stock gs-r engine. this along with the added displacement increases power exponentially-- and this is the real reason why ls/vtecs can work out well with stock internals.
not really.
for example:
for example:
no what i'm saying is that due to the deck height of the LS being lower the combustion chamber size is even lower in an LS, that is once you get rid of the massive chambers of the pr3 head.
I was always told that torque is acceleration and horsepewer is top end now how true that is I don't know but i do know that an ls/vtec is a very inexpensive worthy contender and probably had stock internals with just basic bolt ons to take the itr.
Your right on both parts! Building an ls/vtec is a little more expensive than people think!!
