where to get 600cc injectors
does anyone know where to get these? and what will i need to do to use them. will i have to modify the intake? i know i will prob have to modify the fuel rail. i plan on using a afertmarket fuel rail and fuel pressue reg. this is a b18b motor going into a 94 civic dx. thanks in adcance.
-sean
-sean
RC makes 600 and 650cc injectors. Expect to pay a grip for them. MSRP is like $150+ a piece. If you can get away with 550cc injectors, you can look for the stock injectors off a TT Supra or FD RX7. The Supra injectors will be peak and hold, so you'll need a resistor box and the appropriate injector clips to run them. The FD injectors are saturated, so you wouldn't need a resistor box, but you may still need new clips. The injectors should fit into your rail and intake manfifold fine, but you may need to get new injector seals for the manifold, or bore out your stock ones slightly, since it'll probably be a tight fit. My DSM 450s fit right into my rail without doing anything to the seals, although it's a pretty tight squeeze. The stock rail and fuel lines are actually good to at least 300+ hp or so, so you don't NEED to get a new rail, but you'll probably want an FPR so you can mess with your fuel pressure to match the larger injectors. Oh, and I assume you know that you won't be able to run anything larger than about 310cc on your stock ECM. You can run 450s with an AFC set to trim injector pulse by about 40%, but anything larger and you need a standalone to get them to idle and run correctly. I'm sure you've already looked into that.
i am looking at 350-400 hp range - planning on using hondata new s200 system. i will need the aftermarket fuel rail was looking at the holley rail and injectors. what do you think?
Nice, so the phase-out of the stage I II III IV systems has begun? To be honest, all the aftermarket rails look the same to me. If I were to get one, I'd probably get whichever one I could get the cheapest. As for Holley injectors, I haven't heard anything bad about them.
