which intake is better
with this set up..which intake would provide the BEST over all performance, a STOCK GSR IM, Stock SI IM, or ported and polished SI IM:
2k EX Civic
95 B16A3
stage 2 port and polished head
Mugen 2ply head gasket
98 ITR tranny
Spoon Racing cams
Skunk 2 Racing valve springs
Skunk 2 ti. retainers
Skunk 2 adj cam gears
Unorthodox Underdrive crank pulley
Centerforce dual friction clutch
Comptech header
2 1/4in custom exhaust
Magnecor 8.5mm wires
P30ecu 5800rpm Vtec X-over 8600 rpm limit
short ram intake
Neuspeed Short throw shifter
(i think i got everything)
2k EX Civic
95 B16A3
98 ITR tranny
Spoon Racing cams
Comptech header
short ram intake
the GSR intake will fit on an SI head...they are both b-series heads, and have the same bolt patterns....but anyhoot...decided to use the SI P/P IM, cause its better for midrange which is where the engine seems to lack the most
There's a reason Skunk2 makes so much money selling manifolds, and that is that a Type-R IM will not fit on a b18c1 head.
who mentioned anything about a B15c1 head...my friend has a b16a3 engine..block..etc.....so im confused as to where the worries about an ITR IM fitting a b18c1 is coming from....
Blizzard
Dec 6, 2002 05:26 PM
Jigga
92+ Civic/EL & Del Sol
7
Dec 1, 2002 01:46 PM
Jigga
9
Nov 25, 2002 08:59 PM
