which arp main studs?
Old Jul 27, 2006 | 06:15 AM
iceboy's Avatar
iceboy
Default which arp main studs?
ok so king motorsports lists the same part number for integra/civic with either b16a or b18c (arp-208-5403). The arp catalog lists the part for b18c's as arp-208-5403, and 16's as arp-208-5402 and are 12 point...and summit lists the first part number that king lists but only for b16's...so what the heck studs do i order? are all the be series interhangeable?
these are going on a b18b1 block with gsr girdle and main caps...need those so i cant the damn thing into the machine shop to be line bored!
please help!
thanks
Old Jul 27, 2006 | 09:01 AM
shivers's Avatar
shivers
Moderator Alumni
Call ARP and verify which part you need. I know the ARP head studs are different because of the different block heights. However, I can't say for sure if the main studs are the same for b16/b18. Part numbers in catalogs and on websites aren't always accurate, best to check with the manufacturer to confirm.
2005 s2000
Old Jul 27, 2006 | 09:49 AM
dmacaalay's Avatar
dmacaalay
Monkey See, Monkey Do!
Default ^^^ i agree!!
best to just call and confirm.. you need the arp bolts to match whatever head you are puttin on that ls block..
Old Jul 27, 2006 | 10:56 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
The B16 doesn't use a main girdle. The B18C does. If you are using a girdle, you want B18C studs. Otherwise, B16 studs are what you want.
Old Jul 27, 2006 | 02:07 PM
iceboy's Avatar
iceboy
i called n got it all figured out....
cant even decide if they are necessary tho??
Old Jul 27, 2006 | 06:21 PM
Provocateur
On permanent hiatus
I wouldn't bother unless you either have huge power goals or have lost the stock bolts.
Old Jul 27, 2006 | 09:05 PM
iceboy's Avatar
iceboy
schmoo to the rescue again...thanks man!
