P30s into an LS?
Old Jul 11, 2006 | 09:38 PM
awormofearth's Avatar
awormofearth
sho nuff
Default P30s into an LS?
what kind of compression ratio would a B18A1 get from P30 pistons?
Old Jul 12, 2006 | 12:54 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
The static compression ratio would be around 11:1 assuming you are using a B18B head. With a B16 head, it would bump it up to around 11.5:1. A GSR head would make it around 11.8:1.
Old Jul 12, 2006 | 01:53 PM
awormofearth
sho nuff
what about with the B18A1 head?
Old Jul 12, 2006 | 02:10 PM
Snoopy's Avatar
Snoopy
been there done that
figure it out with www.zealautowerks.com
Old Jul 12, 2006 | 11:06 PM
Provocateur
On permanent hiatus
It would be the same as the B18B head. They are essentially the same heads, so they will yield identical compression ratios.
