turbo Q's
Old Jun 17, 2006 | 12:33 PM
B16a2VTIguy's Avatar
B16a2VTIguy
Built B16a
Default turbo Q's
I have a B16a2 EG hatch and i'm just trying to get my head round the final little bits i dont understand before i go 4 it.....
*Can i run stock injectors on with a T3 (.48 a/r .42 exhaust and .50 wheel)
on say like 8psi? if not will some 450cc's do the job? will i need saturated or peak hold?
*Will my Eudm P30 ecu run crome with the extra boost software?
( i have already 'chipped it with crome)
* will i need a wideband kit too get a proper good tune?
*would anyone beable to send me a base map who's got a similar set up so i can 'fine tune' from that map?
*will a 680mm X 460mm X 180mm intercooler be good enuf for my application?
Thanks for any help, ste
Old Jun 17, 2006 | 06:42 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
I would upgrade the injectors to a much larger size. 450's would be a good choice. If your car has a resistor box, you will need peak and hold, low impedence injectors. If you don't have a resistor box, saturated injectors will be what you would need.
Yes, it will run Crome if it has a removable chip in it. I have personally tuned my car with Crome Pro and the ostrich, so I have some hardware information if you are need help. PM or AIM me.
Yes, a wideband is a necessity if you are tuning it yourself. That is the only way to tell if you have the proper AFR's. You will also benefit from some sort of datalogging program that will record your AFR's for particular engine loads and rpms. Without those two things, you cannot properly tune any car. Here is a good link to get you started on engine theory: http://www.xenocron.com/links.php?page=writeups
A basemap isn't very hard to make yourself. If you need a walkthrough, let me know.
I don't know what size that intercooler is. I think you have the numbers wrong because it converts that to 26 x 18 x 7.
Old Jun 18, 2006 | 08:56 AM
B16a2VTIguy
Built B16a
Thanks das schmoo, that helps alot.
The intercooler i found on the internet had that size listed next to it......i basically want a intercooler pretty much the same size as the centre slatts/vent/mesh area on a eg hatch front bumper because thats wer i'm planning to mount it.
Old Jun 19, 2006 | 01:07 PM
FooD2000's Avatar
FooD2000
Still Water
If you need help pricing out parts, i can also help. I've spent months shopping and piecing so i have a good feel for the market.
Old Jul 1, 2006 | 03:48 PM
B16a2VTIguy
Built B16a
Thanks alot man, that will really help......
Im only looking to buy the major parts needed from the u.s because postage to the u.k is stupid high costs.
At the moment im looking for a T3T04e turbo a good manifold and a downpipe, to get me started with the kit. Any ideas were i cud get a reasonabley priced one from?
I have mapped my ecu with crome now....so thats sorted, but i'll still need a wideband kit with some sort of data logging....any ideas agen were to get this one from?
thanks for the help
Old Jul 7, 2006 | 04:55 PM
B16a2VTIguy
Built B16a
Bump
