Valve clearance setting
Old Jun 10, 2006 | 03:10 AM
psx_pat's Avatar
psx_pat
Default Valve clearance setting
Just wondering what happen when the valve clearance setting for B16A is wider (for ex: intake 0.2 and exhaust 0.25)then factory spec,other then the ticking noise? Lower performance? Thanks.
Old Jun 10, 2006 | 10:59 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
If it is too loose, it will probably make a ticking noise because the cam lobe is slapping the rocker arm instead of smoothly engaging with it and power could be slightly lost because the valve would not go down as far as it would if it were in spec.
Old Jun 10, 2006 | 02:32 PM
psx_pat's Avatar
psx_pat
Thanks,man
Old Jun 15, 2006 | 01:16 PM
AcuraFanatic's Avatar
AcuraFanatic
It's also not good for long term integrity of the valves or cam lobes.
