why is my engine skipping?
Old Jun 6, 2006 | 06:17 PM
dr125m's Avatar
dr125m
Default why is my engine skipping?
i have a 1991 prelude 2.0si i just put new plugs, wires, cap,and rotor on. i also had a can(muffler) put on at the same time and now the car skips after it warms up a little bit. What is wrong? aby suggestions?
Old Jun 6, 2006 | 09:10 PM
jumpman83's Avatar
jumpman83
It's because can mufflers suck. Either that or you might want to check your TPS and ECU, one of those were the fix when mine was doing that. To be perfectly honest, though, I'm not sure which.
Old Jun 6, 2006 | 09:11 PM
jumpman83's Avatar
jumpman83
P.S., I'm assuming what you mean by skipping. You actually should be more specific
Old Jun 7, 2006 | 04:29 AM
shivers's Avatar
shivers
Moderator Alumni
Make sure you routed all the plug wires to the correct cylinders and the right spot on the distributor. Also check the distributor to make sure you put everything back in the correct position ... if not, the car will be out of time. Get a timing light and make sure the base timing is set to spec.
2005 s2000
Old Jun 7, 2006 | 09:19 AM
dr125m's Avatar
dr125m
by skipping i mean when you hit the gas it feels like im running on 2 cylinders. All my wires and everything are run correctly and the timing is fine. i have a silencer for the can wich quites it down to where it used to be and with the size oof the pipe(silencer installed) it should be close to the same backpressure as it used to have but that does nothing for the skip.
